Hi, this is my setup: K8-200, K8204 Z-axis upgrade, E3D-v6 extruder, Windows 10, Arduino 1.68, Repetier Host V1.5.4
I’m having trouble with my printer configuration and wanted to make sure I had the correct firmware and was applying it correctly.
Was going to use firmware_k8200_v2.1.1.zip, but I don’t have the VM8201 (LCD and SD Card controller). Is this still the one to use?
I can upload firmware with Aurdino IDE without issue. Another point of confusion for me is ‘saving to EEPROM’. In Repetier-Host I go to ‘Config’, ‘Firmware EEPROM Configuration’ and I am getting confused. Do I select:
‘Save to EEPROM’ which then pops up with a 'Settings stored to running config. Write Changes to EEPROM?..or do I select: ‘Restore Factory settings’ with the ‘Save retrieved changes to EEPROM’?
Or should it be some other method or software.
Thanks for the patience with pretty obvious answers.
