I’ve just bought EDU06 and I didn’t care of the power supply (in fact I didn’t see that an VAC was needed!).
As I had a 230VAC/12VAC power supply and as I saw that EDU06 requested 9VAC/12VAC I thought to use it but before to plug it I checked and found 15.3 VAC for the output!
I tried then to find the adaptor mentionned into the notice but seems that this is not longer sold!
Firstly, I think that the noticve should be modified the notice accordingly and, maybe, to give some consistent example of adaptor type to be used!
Secondly, I’d like to have your opinion and know if following apteur would be compliant with EDU06 (seen in Conrad site):
[list=]Gerth PTF420901
Block VB 2,0/2/9[/list]
Thanks in advance if you can answer
Regards
