I find that the manual is not clear at all about the criterion for producing an output pulse.
It says something like:
- PULSE: set 0, 1 or 2 to indicate the length of the pulse on the output,
- which itself should occur when the value (I assume the actual counter number) becomes equal to the preset value
- max. 100 mA @ max. 30 V
- “memory function constantly compares the current value with a preset value and activates an output for as long as both are equal or for an adjustable time.”
(" " taken from the cardboard cover) - type of output: ‘open collector’.
But when the counter reaches the preset value, no signal appears on the #4 connector.
Does anybody know what is going on? Is there anything special about’ open collector’ that causes my misunderstanding?
Thanx.
C.
