What is the maximum and minimum output voltage?
I have a couple of questions regarding the VMA03:
  1. What is the maximum and minimum output voltage on each channel?
  2. Can I use the VMA03 to programmatically run two engines in same and different directions?
VMA03 can drive two DC motors independently.
For more info regarding min and max. voltage of driver IC, have a look at the datasheet:
http://www.st.com/web/en/resource/technical/document/datasheet/CD00000240.pdf
I also wonder what the max output voltage of that shield is??
The output voltage of the shield and IC is probably not the same. So pleasy provide us with that information. It is realy important becouse many of us burn our shields unnecessarily.
Hello Sesetra,
See Topic: Max Output Voltage
Best regards,
Velleman Support
