Hi, I have a K8200 with the K8203 and K8204 upgrades, plus seperate power supply to the heat bed so i can heat the bed to 105 degrees. what I would like to know is what filaments can I use to print with other than ABS or PLA. thanks for any info you can give. Ted
I’ve found PETG filaments to be quite good, have had good results with coloufab XT and e3d edge.
Thank you, will try them, all the best. Ted
