What Does the Button Above the SD Card Slot Do?
The title says it all. Thank you!
Reset.
For me it doesn’t seem to reset every time. Sometimes it just causes the display to glitch out without turning off.
Why are there two reset buttons?
It’s connected to the reset of the controller board. So pushing it should reset the whole printer.
[quote=“DanielDC88”]Why are there two reset buttons?[/quote]The second one on the frame is not necessary but easier to push when you need an emergency reset (when something goes awry).
So i tought to have main board bruned, and i moved 2 of the working stepper driver (x and y) to extruder 1 and 2 position, and both have correct voltage (0.89 - 0.925)???
solitaire-champ.com
[quote=“James017”]So i tought to have main board bruned, and i moved 2 of the working stepper driver (x and y) to extruder 1 and 2 position, and both have correct voltage (0.89 - 0.925)???[/quote]Could you explain a bit more what your problem is?
