Somehow, I lost my original setting in " Firmware EEPROM configuration on Steps Per MM on X Y Z and E
Also for future reference does any one know the specs to plug into the “Belt Calculator” and “Lead screw” calculator.
ThaNk you.
W
Hi Waynester,
default steps for the four axes are {64.25,64.25,2560,600} (as found in Marlin’s Configuration.h).
All motors are 1.8°, all drivers set to x16 microstepping, belts are T5 and the rod is standard M8.
Cheers,
kuraasu
