Dear Velleman Product Support,
Reference the WFS210 wireless DSO
I have long been a very impressed and satisfied customer of your test equipment product lines. I raised an issue with the trigger on your HPS140i DSO and you released a fixed version of the firmware - excellent service.
I recently purchased a pair of your WFS210 wireless DSO’s from Maplin Electronics in the UK. I thought it such a neat wireless DSO solution that I raised its availability on the venerable EEVBlog forum where electronics designers, professionals and hobbyists meet. There was much interest in my posting and several purchases of the WFS210 resulted from it.
Having tested the WFS210 I and my fellow EEVBlog forum members are discovering some serious issues with the product. Whilst the hardware appears to be of your usual high standard, the firmware and software appear to leave a lot to be desired and are still very buggy. Little development, if any, appears to have been done on this product since 2014.
Please will you advise whether this WFS210 product is still being supported by your developers or is it now considered ‘abandoned’. If it is still being supported, I am happy to provide the bug reports from the EEVBlog forum.
I hope you will understand that, having highlighted this product to forum members, I feel responsible for them potentially wasting their money.
Bug list to date:
The WFS210 is often not seen by the Android APP even though the Wi-Fi link has connected and an IP address confirmed. This issue can make the unit frustrating to setup and unuseable in many cases.
The Android APP 5us 2us and 1us timebases appear to have an issue with 5us being the smallest available and the 2us and 1us selections making no change to the timebase.
The PC software has no Y shift capability for the two channels.
On the PC software there are two triggers and these can introduce a false phase difference between the channels if both are moved away from the baseline point. Surely only one channel trigger should be active at any one time ?
The WFS210 apparently locks up after 15 minutes of non use and requires a reboot. A power saving function ? but no auto-recovery from it ?
The most serious bug by far is the inability to link the Android App with the WFS210. I personally have experienced this infuriating problem. It appears that the APP cannot see the WFS210 in spite of a solid Wi-Fi link and IP address allocation. It then immediately enters ‘DEMO’ mode. Multiple deactivations of the DEMO mode using the setup menu will eventually lead to a successful connection and correct operation of the APP and WFS210. Many users would have given up on the unit by that time though.
The units that have been tested to date contain the following firmware:
Main firmware : 1423
Wi-Fi firmware: 4.0
Android App: 1.2
Main firmware : 1443
Wi-Fi firmware: 4.41
Android App: 1.2
I look forward to your response on this matter.
Fraser
