I get just errors with W10.
Android is OK.
When will the Windows-10 driver be available?
Driver installs fine under Win10 — but like a lot of drivers for specialist kit you have to do it in Safe Mode the Install Unsigned Driver.
Try doing this before installing the drivers.
- Windows Key + R
- Enter shutdown.exe /r /o /f /t 00 [color=#BF0000]<–These are Zeros Note the spaces[/color]
- Click the “OK” button
- System will restart to a “Choose an option” screen
- Select “Troubleshoot” from “Choose an option” screen
- Select “Advanced options” from “Troubleshoot” screen
- Select “Windows Startup Settings” from “Advanced options” screen
- Click “Restart” button
- System will restart to “Advanced Boot Options” screen
- Select “Disable Driver Signature Enforcement”
- Once the system starts, install the drivers
