Installed the wsf210 program on w10
driver problem
right click on the inf file of the driverfiles and click on install
then go to device management and you see an unknown device
update the driver with: in local folders
then the driver is installed
second problem
when the program is running I get the following error message:
Not enough space: 25008 available 25600 needed
how can I adjust this?
thank you
program with error was on a 32 bit laptop under w10
I put the program on a 64 bit laptop under w10 no problems
driver installed on the 64 bit laptop was as follows:
put the two driver files in a folder on my desktop
open this folder and click right on the inf file and then on install
after that I installed the program WFS210
connect WFS210 with the USB of the laptop
and device management saw the device directly under Ports (com & LPT)
so for 32 bits machines there seems to be a problem with the space (vrtual work space?)
