When I export data from the PC application, it writes the data in a fixed xx.xx format no matter the resolution of the measurement signal, this means that is you measure with high resolution (mV) the signal quality which is stored in the .csv file is extremely poor. Could you please export using more decimals xx.xxxx ? The time stamp would also be a nice feature to have as a separate column.
Anders
Could you please indicate when an updated PC version is available
