Wanting to tweek my K8200 printer, but need help
I have searched this forum and have not found the answer to this question.
Where can I get more of the metal frame rails the K8200 is made with?
I want to make a few changes and shore up the frame. I would prefer to be able to get these in longer lengths so I can cut them to fit what I need. I’m not sure my idea will work the way I invision it, but if it does, I think it will help a lot of others out. As always, I’ll post the results, but for now it’s a little complicated to detail out at this point, and as with a lot of my creations, they morph as I build and discover better ways forward.
Thanks for any help you can provide me on finding these rails.
OH,almost forgot, I also need to find the corner attachment arches/brackets.
Thanks for the help!
Here is a link to the manufacturer of the Aluminum Profile system the K8200 frame is made of :
products.alfer.com/Produkte/Neuh … em-coaxis/
It’s called Alfer coaxis.
You should find the profiles and any available mounting parts there. HTH.
Here is a german reseller :
modelltechnikdirekt.de/Alfer-coaxisZ-Profile
cheers,
Christian
Thank you Sir!
You made my day!
You’re welcome!
I can’t wait to see your results.
