Hi everyone. I’m looking at purchasing a Velleman O-scope, specifically the HPS50. Could someone help me determine if this unit will be able to handle the output voltage of a loudspeaker amplifier?
I’d like to use the oscilloscope to set the gains on multiple Crown Xti1002’s:
crownaudio.com/xti-2-series.html
I’m pushing 1400W out at 4 ohms on these amps. The amps will be installed in the U.S. and running off of 120VAC power. What would the Vpp be? And can the HPS50 handle it? Anything I’d need to know?
I’ve used oscilloscopes to set gains on automotive (12V) amplifiers before but this will be my first time using them for home/business installation on 120V. Thanks!
