Vortex nano 3d printer
my vortex nano 3d printer the sd-card will not show up
Hello @jarnobeerten
Trying to understand your issue …
Is this a newly built Vertex Nano or did the SD card reader have recently stopped working ?
Have you after inserting your SD card, select and click the “init. SD card” item in the LCD screen menu on the Vertex Nano ( and so, did the item “no SD card” change in “print from SD” ) ?
Or are you trying to access an SD card in the Vertex nano from “Repetier” software from your computer connected to the Vertex Nano via USB ?
What kind and size “GB” of SD card (if more than 16GB this is maybe the issue) ?
Have you try another SD card ?
Did your SD card is formated in “fat32” ?
Did the gcode file name use simple charset and dont start with a point ‘.’
Or is your issue something else ?
Trying to help.
Have a good day !
Its new printer but if i try after adding sd card in the slot and press init sd it will not show up the message says No Sd Card
Hello !
So this could by the SD card or the Nano vertex SD card Reader …
What is your SD card Size : 8GB ?
Are you sure your SD card is fat32 formatted ?
Some dust or bad contact in the SD card reader ?
Wrong card insertion ?
Edit 1 : Directly soldered so no cable (but if you can / know check the soldering of the card reader)
“http://images.velleman.eu/manuals/vm8600/02/002.jpg”
Nop see edit 1 : Some defective cable or cable connection issue ?
Sorry no magic anwser …
Hopping this help
Have a good day
Fat 16 was it i bow formated it to fat 32 now it works space is 16gb
Hello @jarnobeerten
Happy for you !
May you have some good printing !
So this topic is solved !
