The voltage on my controller board on one of the pololu’s is fluctuating (from anywhere between 25mV to 900mV), turning the poti, doesn’t change a thing I switched it with on another axis and still the same, does this mean its broke?
btw, the other 3 pololu’s are working fine. It’s a new set, so the controller is brandnew.
Update: I allready found out wat is was, the poti was broken (half of the “body” was missing)
