Hello.
I have a RFID read and write module VMA405.
I connected it to an Arduino, I loaded the example sketch from Arduino.
I can read the Serial number of the card, but the Key seems to be wrong !
On the Monitor, I have :
101 106 251 170 94
Not allowed!
101 106 251 170 94
Not allowed!
101 106 251 170 94
Not allowed!
From the User Manual, I followed this :
10. Bring the MIFARE card or tag in front of the VMA405. The card code will appear on the serial monitor,
together with a “Not Allowed” message.
11. Copy this code, check line 31 in the sketch and replace this card code by the one you copied.
This integer should be the code of your MIFARE card/tag.
int
cards [][5] = {{117,222,140,171,140}};
12. Recompile the sketch and load it into your controller. Now, your card will be recognize
But this doesn’t change anything.
Is there another Key ?
