I bought a VMA354 Tuya IoT Interface module to connect an Arduino UNO to the Tuya Cloud. I cannot test it because all the examples given in the Tuyav librarie (Tuyav-master) exceed the Arduino UNO memory space. Space for data is 2048 and the space used by the examples are always > 2048.
It is mentionned is the documentation that an Arduino UNO can be used, and in the code itself the wiring to connect an Arduino UNO is provided.
Could you tell me how to use this VMA354 module with an Arduino UNO please ?
Thanks for your quick answer, and you give me the solution !
This issue was effectively reported in the github link you posted.
I have downloaded the old version of the library (1.1.0) and now only 55% of SRAM is used, instead of 128% with the last version (1.2.0).
So, for future users : if you want to use Tuyav (VMA354 module) with a lite Arduino version (UNO, Nano …) do not install the 1.2.0 version.
I would appreciate an answer from the Velleman support team (already seen on this forum) , and it could be fair to inform the customer that the last version of the library is no more compatible with the ‘old’ low memory Arduino.
We have seen this post, there’s indeed a problem with the max memory of Arduino Uno / Nano being exceeded with the latest library version 1.2.0 from Tuya.
This has now been passed on to our R&D engineer. This is being investigated. As soon as we have a fix it will be posted here as well as on github.
Thank you for your answer, for the moment I use the previous version 1.1.0.
I would like also to known how to find the VMA354 documentation full manual.
In the source code given in the library it is mentionned as comment :
— TUYAV example program —
v1.0 by BN&PSI @ Velleman NV - nov 2020
works with VMA354 Tuya IoT interface
This example program shows you how to interface with the Tuya IoT interface board & how the timing function is called
