Hello
I’d like to know how to put on the stand or stand by the radio on the VMA11 shield . Because there is a radioON but no RadioOFF.
Thank you
Hello
Thank you
It is explained in the datasheet for the 470X chip (4702=FMradio, 4703=FMradio with RDS).
Simplified, the chip requires the following actions:
1/ power
2/ establish communication protocol on I2C
From then, you can read and write registers over I2C.
The POWERCFG register (0x02) contains a ENABLE (0x02:0) and a ‘DISABLE’ (0x02:6) bit.
Simplified, on start, both bits are 0.
To start the radio working, you set ‘ENABLE’ to ‘1’ . This iw what is done in the ‘RadioOn()’ function of the example.
If you want to stop the radio (in a software controlled manner), the you can set ‘DISABLE’ to ‘1’. There is no such function implemented.
If you are interested in many more possibilities of this chip, see the datasheet [DATASHEET]
At the end of the datasheet you’ll find links to further ressources (Application notes).
Thank DirkH
Thank you for that answer
Unfortunately I don’t know the I2S protocol well and I don’t see how to change a bit on this function simply.
How to send us just a bit 1 on the POWERCFG register
My goal is to stop the radio to earn energy
thank you in advance
Register 0x02 = ‘POWERCFG’
ENABLE = bit 0 of this register
DISABLE =bit 6 of this register
On reset, both ENABLE and DISABLE bits are 0.
You have to set ENABLE=1 to ask the chip to start.
readRegisters(); //Copy the current register values into the software variables
si4703_registers[POWERCFG] = si4703_registers[POWERCFG] | 0x0001; //mask in the ENSABLE bit (bit 0 of register 0x02)
updateRegisters(); //copy the variables to the chip
If you want to stop the radio: set DISABLE=1 to ask the chip to stop.
You should not touch the ENABLE bit.
si4703_registers[POWERCFG] = si4703_registers[POWERCFG] | 0x0040; //mask in the DISABLE bit
When the chip has finished the powerdown cycle, both bits will be reset to 0
You should wait and check the status, e.g. in a loop:
while(true)
readRegisters(); //get fresh register data
if (si4703_registers[POWERCFG] & 0x0041 == 0) break; //if both bits are 0 then break out of the infinite loop
The chip is now ‘off’, whilst keeping all settings (as long as power is applied).
To start the chip up again, set ENABLE to 1:
See data sheet:
And application note AN230 - par 2.1.2 and par 3.2.1
By the way, I guess it’s a typo, but the 2-wire protocol is I2C, not I2S (which is a completely different protocol)
A new category was created for the VMA11, please post there.
