VMA100 gives me 5 volt PWM. Need 10 volt PWM
Greetings,
I have succesfully installed, configured and experimented with a VMA100.
My goal is to regulate a Mean Well HLG-185H-C1400B led power supply using either a PWM signal of 10 Volt or a DC voltage ranging from 0 V to 10V.
My VMA100 now produces a PWM signal from which the duty level I can control from my schetch.
However, The Mean Well device needs a 10 Volt PWM signal.
Any suggestions on how to boost a 5 Volt PWM signal to a 10 Volt PWM signal?
Hope te hear, Adriaan.
The VMA100 can only output 5volts.
You may want to look at the VMA411.
You might need a separate power supply
https://www.vellemanusa.com/products/view/?id=528446
Thank you. Just what I need!
Glad to help.
Good luck with your project.
