Hi Guys,
I was just wondering, is it possible to use the vm8201 as just a general purpose controller? and if so, is there a pinout for the ribbon cable so that I know which pins access what?
Many thanks
Matt
Hi Guys,
Many thanks
Matt
Hi Matt
I can’t find a pinout of the vm8201.
However, for the pinout I would suggest you look for the diagram of the controller, as the vm8201 is connected to it 1:1.
That should give you the correct reading of the signals/pins.
Regards
Rainer
[quote=“mattbrailsford”]Hi Guys,
Many thanks
Matt[/quote]
What do you want to use it for?
This is not “controller”. Only LCD display, encoder, SD card socket and level shifter
Schematic you can found on thingiverse: thingiverse.com/thing:439538/#files under
VM8201_SCHEMATIC.pdf.
