Vm8201 kills usb-connection?
i installed the vm8201 Controller with sd-card as directed. including the Firmware-update and update of repetier-host.
the Printer did its Job, nothing to criticise.
then i wanted to use the usb-connection again, since it is more informative to get temperature Graphs for instance.
the PC however is not able anymore to send commands, although repetier-host Switches the button green to “connected”.
question:
  1. is it worth trying to find a mistake/Option or is the usb-connection killed once the Firmware-update plus vm8201 is installed?
  2. in case of: yes bouth varieties are possible, any idea where to look, what to Change?
i really hope for the dubble-use-version,
thanx for support
hy,
in printer configuration u have to put the value “Disabled” on the combo box “Reset on connect”, and all will be ok :wink:
thanx a lot,
it works now from both directions!
but i wonder where you find out things like that!
does any detailed Manual exist?
No manual, I saw the tip reading the forum one day I had this problem too.
U will learn a lot of things here, trust me :wink:
