VM8095 settings change
My customer is using this VM8095 in an exhibition room. five buttons select five audio fragments, located in map A to E. Every map contains only one audio file. Sometimes, one or two times /month, the system starts to react pretty strange. Any button you press, it always plays the audio fragment in map A. Only a complete reconfiguration of the module can set it back to normal.
Any idea why this happens and a solution to solve this problem?
Greetings,
Bert
It seems the buttons B, C, D etc. are reassigned to play the file in folder A.
When the audio file in folder A was ended or the Pause button was pressed, then if any of the buttons B-F is pressed long, the folder A will be assigned to this button.
Please see:
viewtopic.php?f=2&t=7631
viewtopic.php?f=2&t=7757
viewtopic.php?f=2&t=7536
[quote]Only a complete reconfiguration of the module can set it back to normal.[/quote]You can easily return the unit to its original settings:
  1. Disconnect the power adaptor.
  2. Press the Play/Pause button and keep it pressed when the power is connected again on.
  3. Now you should see on the LCD text “FACTORY DEFAULT”.
  4. Then release the Play/Pause button.
