VM8095 MP3 player board
Heb onlangs een VM8095 MP3 player board gekocht. Maar heb blijkbaar software nodig om deze via voor geprogrammeerde af te spelen.
Kan iemand mij hier mee helpen???
Toon
Please read the forum rules: only posts in French or English are allowed!
You don’t need any software: put your MP3 files on an SD card and they will play.
www.elektronicagoedkoop.nl/Modules/1760 … 53183.html
I already tried it, but when I want to use the external preset buttons he always plays just the first mp3 file.
I want to arrange that when I activate preset button 1 he will play the first mp3, preset button 2 the second mp3… exe
At the link above they speak of a VM8095 programmer for programming the 7 preset buttons (The DLL is downloadable from our site)
Twoinne
[quote]I want to arrange that when I activate preset button 1 he will play the first mp3, preset button 2 the second mp3… [/quote]Please put the first MP3 file to folder A, the second file to folder B etc.
Pressing the preset button 1 will play the file in folder A and pressing button 2 will play the file in folder B etc.
VM8095.
I had the same problem. No software download available for the A to G push buttomns / contact-inputs. The following problem occured also, there is no USB-cable that fits with the VM8095 USB-connector, in order to connect it with a PC. A standard cable with mini USB-connector is to large. My Pentax USB-cable has an even smaller USB-plug, but now this one is to small. The one used on the VM8095 board, is new for me.
I have got the impression, the VM8095 was released to quickly, without the bycoming perefirals. I am very curious how Velleman solves this lack.
By the way, the board works perfect, also for the A - G-keys and contact inputs. The lack on reliability (previous version) on this point seames to be solved.
Because there is no STOP-key, I have made the STOP-function by adding a 825mS Silence MP3-file into the G-directory.
The STOP-function is a must for my applications (emergency avacuate systems). I also want to use the VM8095 for acoustical measurements, using the StiPa test signal.
Question: is there anyone who has experience with the RF-remote, regarding coverage range etc?
WKV, STI Acoustics
PLEASE: ENGLISH or FRENCH (see forum rules)
All other posts will be deleted.
All available software can be downloaded here:
http://www.velleman.eu/support/downloads/?code=VM8095
