Is it normaly that the VM8095 dont hold the noiese Level when i Change mp3 tracks with the preset Buttons?
And the modul dont hold the noise Level when i Switch it off and on.
The settings are saved by long press of the play/pause button.
Press the button as long as the player goes to sleep mode (LCD light turns off).
Usermanual p.7: “If you want this mode for next times after switching off the power you must place the MP3 shortly in sleep mode to save your settings.”
I know abaout this Funktion, but that dont work.
When i press Play in sleep mode the noise Level is not the same as bevor.
Also when i adjust the voice Level with track A and i Play track B ist the same noise leve iadjusted, Play i track A again i have another noise Level (same Level as i Switch power on).
You can try following procedure to fix the problem:
Reset the unit to its original settings:
- Disconnect the power adaptor.
- Press the Play button SW1 and keep it pressed when the power is connected again on.
- Now you should see on the LCD text “FACTORY DEFAULT”.
- Then release the Play button.
