Hello all,
I’m new here, first of all: Hello!
I built a custom project, where a VM8090 is used so switch on/off different lights with pushbuttons, by using the open collector inputs of the board. Works great.
Programming of timers or switch type (mom, toogle etc.) where programmed via Demo Software and hex code. Worked great!
Now I want to add the possibility, that a computer programm runs a loop of switching relays on and of in a pattern, like a demo mode. Because I’m working on batteries, a Rasperry Pi should be the computer, doing that job.
My question: Can the dll library of the board be used on a rasperry as well, or is it just designed to run on a Windows PC? I hope to get some input.
Thanks, Martin
