Dear Vel448
Thanks for the excellent support in this forum. All the answers of your team are of high quality and to the point.
I attached an Autoit script that works with the VM8090 board. The original script receives an Outlook mail and compares the text in the subject of the mail with the text associated with the relay number. I stripped this code from the attached script because it is not relevant for this forum.
Regards,
Ed
; #AutoIt3Wrapper_Au3Check_Parameters= -q -d -w 1 -w 2 -w 3 -w 4 -w 5 -w 6
#AutoIt3Wrapper_Au3Check_Stop_OnWarning=N
; #INDEX# =======================================================================================================================
; Title .........: Relais
; AutoIt Version : 3
; Language ......: English
; Description ...: Connects to Velleman 8090 8-channel USB Relay card and reacts on Outlook received message.
; Author(s) .....: Ed Nieuwenhuys
; Version........: 0.15
; Version 1.0....: 29131220 (YYYYMMDD)
; Modified.......:
; Changes........:
; Resources .....: Velleman K8090D_DLL.pdf, K8090_PROTOCOLMANUAL.pdf
;~ Func TestCardFunctions()
;~ Func oOApp_NewMailEx($sOL_EntryId)
;~ Func _Exit()
;~ Func Activate_RelaisNr_Velleman_K8090D_card($IntRelaisNr)
;~ Func Deactivate_RelaisNr_Velleman_K8090D_card($IntRelaisNr)
;~ Func Toggle_RelaisNr_Velleman_K8090D_card($IntRelaisNr)
;~ Func Query_Relais_Status_Velleman_K8090D_card()
;~ Func TimeInSec_RelaisNr_Velleman_K8090D_card($IntRelaisNr, $Seconds)
;~ Func Set_Relay_Timer_Delay_Velleman_K8090D_card($IntRelaisNr, $Seconds)
;~ Func Reset_Velleman_K8090D_card()
;~ Func Connect_Velleman_K8090D_card()
;~ Func USB_DLLOpen()
;~ Func Close_Velleman_K8090D_card()
;~ Func StartApp()
;~ Func ActOnOutlookMessage()
;~ Func SetRelayText($nr)
;~ Func TurnOnCheckbox($nr)
;~ Func TurnOffCheckbox($nr)
;~ Func ToggleCheckbox($nr)
;~ Func ActOnCheckbox($nr)
;~ Func WriteRelayTextToFile()
;~ Func ReadRelayTextFromFile()
;~ Func CommandReceived($cmd, $mask, $param1, $param2)
;~ Func StatusReceived($hWnd, $iMsg, $wParam, $lParam)
#include <ButtonConstants.au3>
#include <EditConstants.au3>
#include <GUIConstantsEx.au3>
#include <WindowsConstants.au3>
#include <WinAPI.au3>
#include <File.au3>
Global Const $CMD_SWITCH_RELAY_ON = 17
Global Const $CMD_SWITCH_RELAY_OFF = 18
Global Const $CMD_TOGGLE_RELAY = 20
Global Const $CMD_QUERY_RELAY_STATUS = 24
Global Const $CMD_SET_MANUAL_OPERATION_MODE = 33
Global Const $CMD_QUERY_MANUAL_OPERATION_MODE = 34
Global Const $CMD_START_RELAY_TIMER = 65
Global Const $CMD_SET_RELAY_TIMER_DELAY = 66
Global Const $CMD_QUERY_TIMER_DELAY = 68
Global Const $CMD_BUTTON_STATUS = 80
Global Const $CMD_RELAY_STATUS = 81
Global Const $CMD_RESET_FACTORY_DEFAULTS = 102
Global Const $CMD_GET_JUMPER_STATUS = 112
Global Const $CMD_FIRMWARE_VERSION = 113
Global Const $WM_K8090_STATUS = $WM_USER + 1
; This script loops until Shift-Alt-E is pressed to exit.
HotKeySet("+!e", "_Exit") ;Shift-Alt-E to Exit the script
;HotKeySet("{Esc}", "_Exit") ;Shift-Alt-E to Exit the script
Global $dll
Global $dllOpen
Global $HLabel
Global $Compoort = "COM3"
Global $EmailMessage = "Erreur"
Global $FileName = @ScriptDir & "\RelayText.txt"
Global $AlarmTimeSec = 60 ; turn on alarm for .. seconds
Global $Relaytext[9]
Global $input[9]
Global $Button[9]
Global $Checkbox[9]
; Initialise card and gets handle to card ($dll)
$dll = Connect_Velleman_K8090D_card() ; Make the connection
Reset_Velleman_K8090D_card() ; Reset all relays
StartApp()
_Exit()
; test card functions`
Activate_RelaisNr_Velleman_K8090D_card(4)
MsgBox(4096,"Card test", "Turn relay 4 on and off after this message disappears",2)
Deactivate_RelaisNr_Velleman_K8090D_card(4)
TimeInSec_RelaisNr_Velleman_K8090D_card(8, 2)
MsgBox(4096,"Card test", "Turn relay 2 on and off after with timer dealy func after 2 sec",2)
For $m = 1 to 2
For $n = 6 to 8
Toggle_RelaisNr_Velleman_K8090D_card($n)
TimeInSec_RelaisNr_Velleman_K8090D_card($n, 1)
Sleep(1100)
Next
Next
EndFunc
Func _Exit()
MsgBox(4096,"Program ended", "Program ended",2)
Exit
EndFunc ;==>_Exit;
; *******************Velleman card K8090D Functions ******************************
$HexRelaisNr = BitRotate(1, $IntRelaisNr - 1)
$result = DllCall("K8090D.dll", "none", "SendCommand", "HANDLE", $dll, "BYTE", $CMD_SWITCH_RELAY_ON,"BYTE", $HexRelaisNr , "BYTE", 0,"BYTE", 0 )
Return $result
EndFunc
$result = DllCall("K8090D.dll", "none", "SendCommand", "HANDLE", $dll, "BYTE", $CMD_SWITCH_RELAY_OFF,"BYTE", $HexRelaisNr , "BYTE", 0,"BYTE", 0 )
Return $result
EndFunc
$result = DllCall("K8090D.dll", "none", "SendCommand", "HANDLE", $dll, "BYTE", $CMD_TOGGLE_RELAY,"BYTE", $HexRelaisNr, "BYTE", 0,"BYTE", 0 )
Return $result
EndFunc
; The board will respond with a 'Relay status (51h)' packet.
$result = DllCall("K8090D.dll", "none", "SendCommand", "HANDLE", $dll, "BYTE", $CMD_QUERY_RELAY_STATUS,"BYTE", 0, "BYTE", 0,"BYTE", 0 )
Return $result
EndFunc
$ISec = int($Seconds)
If ($ISec >32767) Then $ISec =32767
$HiByteSeconds = Int($ISec / 255)
$LowByteSeconds = Mod($ISec, 255)
; MsgBox(4096,"Seconden ", $ISec & " : " & $LowByteSeconds & " : " & $HiByteSeconds)
$result = DllCall("K8090D.dll", "none", "SendCommand", "HANDLE", $dll, "BYTE", $CMD_START_RELAY_TIMER,"BYTE", $HexRelaisNr, "BYTE", $HiByteSeconds,"BYTE", $LowByteSeconds )
Return $result
EndFunc
$result = DllCall("K8090D.dll", "none", "SendCommand", "HANDLE", $dll, "BYTE", $CMD_SET_RELAY_TIMER_DELAY,"BYTE", $HexRelaisNr, "BYTE", $HiByteSeconds,"BYTE", $LowByteSeconds )
Return $result
EndFunc
$result = DllCall("K8090D.dll", "none", "SendCommand", "HANDLE", $dll, "BYTE", $CMD_RESET_FACTORY_DEFAULTS,"BYTE", 0, "BYTE", 0,"BYTE", 0 )
Return $result
EndFunc
; Basic Velleman card K8090D Functions
USB_DLLOpen()
$n=1
Do ; check if a card between COM1 and COM128 is connected
$Compoort = "COM"& $n
$Result = DllCall("K8090D.dll", "long", "OpenDevice", "str", $Compoort)
; MsgBox(4096,"Connect Velleman",$Result[0] & " " & @error )
$dll=$result[0]
$n=$n+1
Until $dll >0 or $n > 128
If $n > 128 Then
MsgBox(4096,"Connect Velleman", "No COM1-128 connection found" )
_Exit()
EndIf
Return $result[0]
EndFunc
Func USB_DLLOpen()
$dllOpen=DllOpen("K8090D.dll") ; openenen DLL
$dll = $dllOpen
EndFunc ;==>USB_DLLOpen
Local $Result = DllCall("K8090D.dll", "long", "CloseDevice","HANDLE", $dll)
DllClose($dll)
Return
EndFunc
;************************ StartApp ===================================================>
Func StartApp()
; Dimensions of the window
$x = 48
$y = 10
$b = 200
$h = 21
$d = 20
; Create the window
Global $Form = GUICreate("Outlook mail <-> Vellerman 8090 board control", 405, 350, 302, 218)
; Tell the DLL that we want to receive WM_K8090_STATUS messages
DllCall($dllOpen, "BOOLEAN", "RegisterListener", "HANDLE",$dll, "HWND",$Form)
; Also tell the GUI that we want to receive those messages
GUIRegisterMsg($WM_K8090_STATUS, "StatusReceived")
For $i = 1 to 8
$Input[$i] = GUICtrlCreateInput("Message" & $i, $x, $y + ($i * 30), $b, $h)
$Checkbox[$i] = GUICtrlCreateCheckbox($i, $x+245, $y+1 + ($i * 30), $d+10, $d)
GUICtrlSetState(-1, $GUI_UNCHECKED)
$Button[$i]= GUICtrlCreateLabel(" " , $x+220, $y+1 + ($i * 30), $d, $d)
GUICtrlSetBkColor($Button[$i], 0x00FF00)
$Relaytext[$i] = "Message #" & $i
Next
$HLabel = GUICtrlCreateLabel("Last message will be shown here", $x, ($i+1) * 30)
GUISetState(@SW_SHOW) ; show the created window
ReadRelayTextFromFile() ;read the 8 texts from File and place thge in the input fields of the Window
TestCardFunctions()
While 1
$nMsg = GUIGetMsg()
Switch $nMsg
Case $GUI_EVENT_CLOSE
For $n = 1 to 8
Deactivate_RelaisNr_Velleman_K8090D_card($n)
Next
Exit
Case $Input[1]
SetRelayText(1)
Case $Input[2]
SetRelayText(2)
Case $Input[3]
SetRelayText(3)
Case $Input[4]
SetRelayText(4)
Case $Input[5]
SetRelayText(5)
Case $Input[6]
SetRelayText(6)
Case $Input[7]
SetRelayText(7)
Case $Input[8]
SetRelayText(8)
Case $Checkbox[1]
ActOnCheckbox(1)
Case $Checkbox[2]
ActOnCheckbox(2)
Case $Checkbox[3]
ActOnCheckbox(3)
Case $Checkbox[4]
ActOnCheckbox(4)
Case $Checkbox[5]
ActOnCheckbox(5)
Case $Checkbox[6]
ActOnCheckbox(6)
Case $Checkbox[7]
ActOnCheckbox(7)
Case $Checkbox[8]
ActOnCheckbox(8)
Case $HLabel
MsgBox(4096,"Outlook mail","Hlabel",2 )
ActOnMessage()
EndSwitch
WEnd
EndFunc
; ************************** ==> End startApp
; Checks the received subject mail message with the eight texts in the RelayText fields and turn on the checkbox for ($AlarmTimeSec) seconds
Func ActOnMessage()
Local $Relaynr
For $n = 1 to 8
If StringUpper($Relaytext[$n]) = StringUpper($EmailMessage) Then
TimeInSec_RelaisNr_Velleman_K8090D_card($n, $AlarmTimeSec)
$Relaynr=$n
EndIf
Next
MsgBox(4096,"Received message", StringUpper($EmailMessage),2 )
Return $Relaynr
EndFunc
; Place the text from the input field in the SetRelayText array
$Relaytext[$nr] = GUICtrlRead($Input[$nr])
EndFunc
;Turn on the checkbox and color
GUICtrlSetState($Checkbox[$nr],$GUI_CHECKED)
GUICtrlSetBkColor($Button[$nr], 0xFF0000)
EndFunc
;Turn off the checkbox and color
GUICtrlSetState($Checkbox[$nr], $GUI_UNCHECKED)
GUICtrlSetBkColor($Button[$nr], 0x00FF00)
EndFunc
If GUICtrlRead($Checkbox[$nr]) = $GUI_UNCHECKED Then
TurnOnCheckbox($nr)
Else
EndIf
EndFunc
If GUICtrlRead($Checkbox[$nr]) = $GUI_CHECKED Then
Activate_RelaisNr_Velleman_K8090D_card($nr)
EndIf
Deactivate_RelaisNr_Velleman_K8090D_card($nr)
EndIf
EndFunc
Local $hFile = FileOpen($FileName, 2) ; 2 = Write mode (erase previous contents)
For $n = 1 to 8
FileWriteLine($hFile, $Relaytext[$n])
Next
FileClose($hFile)
EndFunc
; Open file and append second array
Local $hFile = FileOpen($FileName, 0) ; 0 = Read mode
If $hFile = -1 Then
MsgBox(0, "Error", "Unable to open file." & $hFile & "- "& $FileName,10)
FileClose($hFile)
WriteRelayTextToFile() ; write default text
Return
EndIf
For $n = 1 to 8
$Relaytext[$n] = FileReadLine($hFile)
GUICtrlSetData($Input[$n],$Relaytext[$n])
Next
FileClose($hFile)
EndFunc
; This function is called every time the K8090 sends
; a command to the computer. In this example, we catch
; both the button status and relay status commands.
Switch $cmd
Case 0x50
; MsgBox(4096, "Button status", Hex($mask, 2),1) ; show which buttons are pressed
Case 0x51
; MsgBox(4096, "Relay status", Hex($param1, 2),1) ; show which relays are switched on
For $n = 0 to 7
; MsgBox(4096, "Relay status", $n +1 & ": "& BitAND(2 ^ $n, $param1) & " - " & Hex($param1, 2),1) ; show which relays are switched on
If BitAND(2 ^ $n, $param1) = True Then
TurnOnCheckbox($n+1)
Else
TurnOffCheckbox($n+1)
EndIf
Next
EndSwitch
EndFunc
; This function is called every time the DLL sends
; a WM_K8090_STATUS message to our GUI window. The message
; can be broken down into a K8090 Command message.
Local $cmd, $mask, $param1, $param2
; Filter out the information relevant to us
$cmd = BitAND(BitShift($lParam, 24), 0xff)
$mask = BitAND(BitShift($lParam, 16), 0xff)
$param1 = BitAND(BitShift($lParam, 8), 0xff)
$param2 = BitAND(BitShift($lParam, 0), 0xff)
;MsgBox(4096, "Status received", Hex($cmd,2 ) & " - "& Hex($mask, 2) & "- "& Hex($param1, 2) & " - "&Hex($param2, 2),10) ; show which relays are switched on
EndFunc
