Hoping someone here can assist me:
I need a set of relays that I can control via serial commands. I think the VM8090 will do the job. My question is, can I send a serial command directly to the box or do I need to build a separate program/project that listens for the command and closes the relay.
I have a scoreboard control system that operates by sending commands (including serial commands) from script buttons. I would like to be able to add a line of serial command code (like “close relay 1 on USBx”) and control the relay.
Is this doable?
-Larry Mitchell
Mavrick Productions
Columbus, Ohio
