Hi all!
A good friend of us (Joel), has made a a small Windows application to display the data logged by the Earth Listener. It works by loading the log file on the SD card into the program and then displays the data in a convenient way.
We offer this exclusively to our forum members to have a first preview!
You can download the software here: https://velleman.bitrix24.eu/~qLlYy
The zipped package includes the executable and the source code (developed on Visual c++ with mfc).
Nothing special about this tool, it is intuitive to use. In the “examples” directory, are stored the some .CSV files that Joel has used to analyze and fix the logs…
Since the EarthListener is not using a real-time clock and is logging the amount of seconds since the boot, you can set the start recording data manually, so this is fixed in the reporting tool.
The application can also split a file which contains several recordings.
“VEListener” is much more comfortable and reliable than using Excel and it can open very large files, what Excel cannot do. Have fun with it and be sure to leave your feedback here!
Kind regards,
VEL342
