Hello
Before buying the VM206 module, I wonder if the timing sequence starts when power (12VDC) is applied or do I have to manually start the sequence by pressing the start button .
I would like to use a “On delay” which starts when power is applied (to delay the start of a circuit which should then stay on until power is disconnected).
Do I have to bridge the start button in closed position?
Regards!
