I have a vm204 and have changed the ip address and it turns all LEDs red, orange and green on and he no longer works
I could not get to the factory settings him
with the jumper on, it come to be in fashion but proggrameer my IP adders does not work and can not also update him after a while you blink the red LED and after a while the green and orange stay on .
I give him also through the MAC address a fixed IP but that does not work.
Yes this is a problem we’ve recently fixed please upgrade your firmware with the version 1.1
You can download the Firmware here => velleman.eu/downloads/files/ … re_1_1.zip
Follow the firmware upgrade section in the manual.
If you don’t remember your IP address check your router.
In the firmware upgrade mode the DHCP client is always enabled. So there must be a DHCP server in your network configuration.
VEL337
Hi!
I have ths same problem. I have had the VM204 up and running, after IP-adress change all leds (red, yellow, green and the red power) is on, HW reset does not work. VM204 not reacheble in my router. No matter what I do all the leds are on…
Ver.1.0.
Hi
As stated please upgrade your Firmware to V1.1 this fixes the bug when setting a fixed ip address
Best Regards
VEL337
[quote=“retepnosslin”]Hi!
Ver.1.0.[/quote]
SOLVED!
Upgrading to fw 1.1 and it works again!
Great!
