VM202 USB board
HI
I have purchased two of these little boards - they look interesting as a low-cost means of providing mp3 background musinc in our shop (saves having to change the CDs every 40 minutes!)
It’d be great if they could play ‘random’ tracks - I notice that the pcb seems partly unpopulated, and that there are unused connector pads, particularly J2 ‘R/LN’ - would it be too much to guess that connecting RN to the central ‘Ground’ pin would cause ‘random’ track play ?
Have you any additional info on these boards, please ?
Adrian
Sorry, there is no way of playing random tracks with this unit.
Hint: shuffle the files (e.g. by adding a random number in the filename and then sorting them alfabetically) and put them on a USB stick.
Next, leave the player powered. It will continuously loop all files.
Thanks for the reply.
Do you have additional info / cct diagram on this board - as it would be interesting to know what the extra connections are for!
Adrian
Please see this post:
http://forum.velleman.eu/viewtopic.php?f=2&t=7927
Grand - thanks
I bought 10 pieces of this unit and I use them in deices I built.
I have some feedback:
  1. I bought 10 new 2GB USB-Sticks and they did work only sporadically.
    Older USB-Sticks seem to work fine. I tried different from 64MB to 1GB.
  2. for my devices it’s not good that the modules start playing after power on.
    It would be great if there could be a jumper, where I can define to play or not after power up.
    Or only begin to play when I press the start button.
Hope you can give us a Firmwareupdate, that we can put on a USB-Stick and update the Device.
Greets - Helmut
Sorry, these devices are not programmed devices, so they cannot be updated.
it is possible to ad 2 buttons for volume control
