Dear, I am looking for a way to configure two i.p. addresses into the iPhone app, 1 internal i.p. for internal use and 1 external i.p. for external use (3G).
Hopefully someone can tell me the way…
The iPhone app has one IP address that it can connect to. This IP address can be changed from the iPhone settings menu.
I already knew that… that’s why I posted my question… there must be a work around. I will try with a DDNS to see if I can have local access through DDNS as well… I was hoping for a proper solution.
Question for velleman support:
why the Remote control software you put on your web site is potentially harmfull?
my windows blocked it.
can you upload an other good one?
Best regards
justin.
The software is not potentially harmful, you will need to allow it to operate normally.
