Vm201
is there a more complete manual/operating instruction lis.
i find that the entries i make are lost on power up.
is this normal?
What do you see on the display when the VM201 is powered on?
When you press the control button (button next to the network plug) on the VM201, does the display show different information? (ip address, etc.)
The reason I ask is because if you hold this button at power up, the VM201 is reverted to factory defaults. If this button has not been installed or soldered correctly, the button may accidentally (always) be in a pressed state.
