hello ,
i am client with belgacom , is ther someone that nows wich setting i must change so i can use tihis module via internet ?
thank you
hello ,
thank you
This solely depends on your router. If you have a B-Box, look up the manual for the B-Box and make the adjustments similar to the examples in the manual of the VM201.
Have you looked at the document from the link below?
http://www.vellemanusa.com/downloads/0/user/usermanual_extended_vm201.pdf
