VM201 sometimes turns to be the DNS server for my network!
Hi there,
Something irritating happend to me, a couple of times.
I have a router in my network, that has a DHCP server running.
DNS server is the (cloud based) GoogleDNS system, so I do NOT have a DNS server in my network.
My VM201 is connected to my network via an ethernetcable (via a 48port HP switch) to my LAN.
(fixed) IP = 192.168.2.75
For SOME reason (when, by accident VM201 gets disconnected from the power, and reboots when powersupply is reconnected) and my VM201 takes over DHCP from my local network-router!!!
The DHCP server becomes: 192.168.2.75 !!! and also DNS…
From that moment on, my network is getting totally NUTS, servers are not reachable anymore, etc.
Settings in my VM201 (Build: 1236, Build date: Sep 07 2012 08:56:42, TCPIP Stack: v5.42):
email features: OFF
DHCP = OFF
Primary DNS: 8.8.8.8
Anyone has this problem, or knows a solotion??
Best regards
Robbert / PA3BKL
I think there is a firmware update for that.
You can download it from the link below.
http://www.vellemanusa.com/support/downloads/?code=VM201
I hope this helps.
[quote=“Wrong Way”]Hi,
I hope this helps.[/quote]
WOW!!
Thank you VERY much!!
I upgraded the firmware.
I looked in the downloaded file archive and hoped to find some ‘changes’ documents, in order to find out WHAT has exactly changed/bugs fixed.
Is there such a document available??
Thanks in advance!!
Robbert / PA3BKL
You may want to read this thread.
[url]VM201 is being a rogue DHCP server]
However you are saying yours acts like a DNS server.
Still it may help you.
