Hello with respect,
I bought this product by charging, I am satisfied with the product specifications but would have improved with some necessary qualities.
The first would be to keep ON state when the module suffers a power failure. All contacts return to OFF after refueling. The timer does this but not for “Ouput status”.
The second is in the “Timer program” menu - PULSETIME - for “Day:” adding and the “Every hour” option, so by simple upgrading you can pulse commands for a single relay … that I really need for my project. I did not notice before buying the product that I can not do that.
The third suggestion would be to add SNTP time and local mode option, as any router or server does without the need for an intrnet connection that can be lost anytime.
And the last one is a remote resetting tool that would be greatly helpful if I did not have any response from the fixed IP mode. The only option is a local reset that does not allow me to do this when I need it.
Thank you,
P.S. is a very good product at the house of man
Gaju Gabriel
