Vm201 relay?
I was wondering what the max switching current per single channel is. I need at least 120-125.
will this card work for my application?
thank you for your time
If you are asking if each relay can handle 120 - 125 amps.
No this will not work for your application.
Specs are below.
8 relay contacts: 12A @ 30Vdc or 16A @ 230Vac
1 input: dry contact or voltage input 5…20Vac or dc
power supply: 12Vac/500mA
