Is er iemand die kan uitleggen hoe je van waar dan ook ter wereld de VM201 bestuurt als die in een LAN zit achter een Proximus BBox3?
Met mijn IP camera’s is dit allemaal goed gelukt maar voor de VM201 schijnt de handleiding me toch iets te beknopt.
Sorry for we can’t supply a manual for each model of router with different softwares/UI.
What you are looking for is portforwarding.
Please google “portforwarding bbox 3” which you’ll find probably your answer
i’ve found this which should get you started
proximus.be/support/en/id_s … tml#/bbox3.
A warning, i do know that Proximus is blocking port 80. You can remove the block in your myProximus account.
Best Regards
VEL337
Thanks anyway, although I already found the solution before your reply.
If anyone else has problems with this, you can leave a message here and we will try to sort it out.
