VM201 power supply
Hello Everybody,
i need some help to connect 12 DC Power Supply to my VM201.
I can`t see if in the manuel the Supply Voltage polarity for PLUS is left oder right,
so im not sure an can only guess if Terminal 1 is PLUS and 2 is MINUS.
Maybe anybody can help and can confirm how to connect my VM201 correctly.
Is this connection right?
Thx very much - best greetings from Germany
The VM201 power supply input has no polarity indication since it requires 12VAC
You could try to run if from 12VDC (polarity is not important) but it won’t work reliably unless you use an unregulated 12VDC adaptor.
Thank you very much for your quick response.
Can you recommend one special power supply?
Maybe via pn?
i would buy this one:
amazon.de/Universal-AC-AC-St … il+12+v+ac
Yes, the specs are OK, but it is a bit expensive if you ask me…
Today i received the Power Supply, it works perfect togehter
Is it possible to use two VM201 in the name network?
By use differnt IP Adresses i think it will work, or will there any interruptions?
What about the use by Apple IOS, can i control 2 VM201 with one iphone application?
Multiple VM201 on the same network is no problem, they will get different IP addresses. Your port forwarding will be a bit more difficult, if you need that.
You can control them all with an app, but you will need to change the IP address every time, which may not be overly practical.
