I have a VM8090 8-CHANNEL USB RELAY CARD lying around here for quite a while. I wanted to use it to control my lights in my house when I’m not at home (so through my smartphone).
If I want to do that with a VM8090, am I right that I need some kind of seperate controller like a Raspberry Pi to run the server software, and to connect to the internet?
Because maybe then it’s a lot easier to just buy a VM201…it seems to do exactly what I want. Or are there any other important differences between the two for my situation?
[quote=“VEL337”]Be Aware the e-mail functionality is not secured![/quote]Meaning that TLS and SSL which are required by a lot of e-mail providers are not supported
[quote=“VEL337”]There are no plans to do this simply there is no room more in the processor to add this functionality.
Also if you have the time you could wait a few months because something awesome is coming ;)[/quote]
Thanks for the info…I’ll wait for the awesome part then!
Aha…do I understand correctly that with this card, I can just connect the card via ethernet to my pc and write a Windows application for it to control the relais?
That would be awesome indeed because software development is not a problem, but I’m not familiar enough with Linux.
Sorry can’t give a date atm.
And yes. You can control it with a windows application through a socket.
The firmware will be in C, the webages will be ofcourse in HTML/Javascript, and the apps will be written in C#
I hope to resume the project in a couple of weeks.
