I’m new to the VM201 module
but is there some possibility for a firmware update or patch,
so I can use the input-command linked to an output-command?
I want to use it for my koi-pond, when the water level is low, there will be a trigger to the vm201
So I want to activate my water pump with an output-command
Sorry, this is not possible. I’m sure you’ll understand that we do not have the means to supply firmware updates on demand.
In this case: even if we would have the means, the controller in this item has no more room left for extra code.
[quote=“VEL417”]Sorry, this is not possible. I’m sure you’ll understand that we do not have the means to supply firmware updates on demand.
In this case: even if we would have the means, the controller in this item has no more room left for extra code.[/quote]
i understand…
but i thought it would be a “easy” thing just to link (example) only output 1 with the “dry-input” (instead of the email thingy …)
