Dears, this time i’m facing another problem: my VM201 is crashing (no reaction, all the relays stucks)
after 3 or 4 days, so i have to restart it every four days.
How can i resolve this matter? is it a firmware problem? I’m runing the Build:1342.
Thanks in advance for your help.
Justin.
Please do not start a second topic for the same issue.
Also: This is not an answering service, it is a forum.
Please allow the forum members some time to respond.
This will be difficult to solve from a distance.
There are no known issues with this firmware version.
To determine the cause of troubles, you could disconnect all relay outputs and continue to use the card as you did before.
If it does not crash anymore, then the problem is related to interference induced via the relay contacts.
