Hello, my problem is I can not connect with vm201 Blast from my mobile using data connexion, but using wiffi if I connect.
I have opened port 9760 and the correct IP address.
My question is: I need to do more in the ruter??.
Thank you very much.
My other question: Is it possible to connect with the phone from miles away with Blast vm201 …???
Yes or NO ???
Unfortunately we don’t know what “Blast” is, so we can not give you any advice…
Hello, my problem is I can not connect with vm201 from my mobile using data connexion, but using wiffi if I connect.
If you are sure you set up port forwarding correctly and you are using the correct IP addresses for everything, then the problem may be outside of your control. For example, your mobile connection may not allow port 9760 to be used.
