PRM
June 20, 2013, 1:44pm
1
hi,
have a problem with the VM201 app for iPhone … about the app I do not have access to VM201 (Unable to connect to server, please verify the settings …)
but through Safari on the iPhone and iMac (VM201 ) everything works. I also port 9760 (TCP) released … no chance the app does not always work the same message!??
Do you have an advice?
VEL448
June 20, 2013, 2:11pm
2
Try 198.168.178.42/
If that url does not work you have the wrong IP address
PRM
June 20, 2013, 3:15pm
3
It does not work properly … The IP appears on the display of VM201 … how do I find out the correct IP?
PRM
June 20, 2013, 3:47pm
4
So but the ip works with Safari but the app still does not work VM201?!?
Did you go through the settings on the VM201 to verify that the port “9760” is correct?
PRM
June 20, 2013, 4:37pm
6
[quote=“Wrong Way”]Hi,
Did you go through the settings on the VM201 to verify that the port “9760” is correct?[/quote]
I have also checked … port is 9760???
Is your phone on the same network?
PRM
June 20, 2013, 5:22pm
8
Is your phone on the same network?[/quote]
Router - 198.168.178.1
iPhone 4 (6.1.2) ip - 198.168.178.63
VM201 - ip - 198.168.178.42
Ok this is very strange.
Have you tried to reset the unit and return it to it’s factory settings?
Turn the power off
Press and hold the “Clock / Network settings” button.
Turn the power on but keep the button pressed for about 10 seconds until you get a message on the LCD screen.
Another thought.
If IPV6 is turned on in your phone you might try turning it off.
I think the VM201 only speaks IPV4
PRM
June 20, 2013, 6:42pm
11
[quote=“Wrong Way”]Another thought.
I think the VM201 only speaks IPV4[/quote]
everything is OK. It works. It’s really weird. have directly without the router to Mains switch and it works!!!
THANK YOU for your support.
Is the app VM201 open source? I would like to change.
Glad to hear it’s working.
But I don’t understand what you are saying.
No the VM201 is not open source.
However that have posted the protocols in the VM201 group so you can write your own software.
Enjoy!!
PRM
June 20, 2013, 8:04pm
13
I had the vm201 connected to switch and the switch to the router … does not work. the vm201 directly connected to router … work.
PRM
June 21, 2013, 8:14am
15
I can 2 or 3 vm201 control along with an app?
Work together more vm201?
VEL417
June 21, 2013, 8:36am
16
Sorry, this is not possible with this app.
