I have a problem with the VM201 ethernetrelaiscard if i turn on the VM201 it works good but my Humax HD receiver can’t make a connection anymore with the internet if i turn of the VM201 everything works fine again! Can anyone tell me what goes wrong?
Both have a unique IP address but the Humax sees the VM201 as a server instead of the router. In other words, the Humax wants connect to the VM201! Both the Humax as VM201 have a static ip address.
Just another guess since I don’t know all of your settings.
Is the VM201 IP address set the same as the gateway (router)?
Are the settings for the Humax (gateway, DNS, and other settings) pointing at the IP address of the VM201?
Sounds like you need to check all of the settings for each unit.
These are the used IP addresses:
Windows PC: 192.168.178.22
Airport extreme router: 192.168.178.12
VM 201: 192.168.178.30
Humax HD receiver: 192.168.178.35
NAS: 192.168.178.23
DHCP is activated on the modem/router and i have given all the above components a fixed IP adress (static lease). The VM201 is connected directly to the modem router (Ubee) and behind the router/modem is the Apple Airport Extreme with the Humax HD receiver.
Settings of the VM201:
NETBios name: VM201
IP adress: 192.168.178.30
Gateway: 192.168.178.1
Sub: 255.255.255.0
DNS: From my ISP
You posted Airport extreme router: 192.168.178.12
But you said the gateway for the VM201 is 192.168.178.1
On most networks the gateway is the router.
So your Airport (router) should have an IP address of 192.168.178.1
Or the gateway setting for the VM201 should be 192.168.178.12
Now back to the original question what are all of the settings for the Humax?
Exactly, I have a modem/router from my internet provider and the airport extreme as an extra wireless AP router. Ip address 192.168.178.1 is the gateway address (LAN) of the modem/router from the ISP and the Airport Extreme is behind that router!
The Humax is on static ip and gateway address is 192.168.178.1 (the Ubee router / modem). As far as I can see, all settings are correct.
To be sure: your Airport Extreme operates solely as ACCESS POINT and NOT as ROUTER? When you would have configured your Airport Extreme as router, you can’t use the gateway of your modem and you can’t use the same 192.168.178.x adress range. If you configured it as a router (if possible, I’m not Apple minded) you should change that to Access Point.
Just as a test to hopefully get some direction of where the problem might be.
If you have an extra port on the Airport Extreame have you tried plugging the VM201 in to it?
I have downloaded the manual for it but do no see any setting to make it a bridge.
Have you tried to change the IP address of the VM201?
