Hi there,
can not connect to the VM201 DYNDNS.
The browser displays only confused characters:
“LNRELAY 1 KNRELAY 2…”
You are browsing to the port used by the iOS app. So you are seeing the raw communication sent between what should be the app and the VM201.
So the good news is that your port forwarding is ok if you want to use software (other than your browser).
If you were expecting the web interface, then you should have port forwarded the HTTP port (default 80).
Thanks for the answer!
I have port 84 forwarded in the router for VM201 and VM201 entered in this port.
Port forwarding works perfectly from the outside with my cameras in the network.
What must I do to get from outside the internal network to the web interface of the VM201 and to perform switching operations there.
Thank you!
