I’m intended to buy the VM201 Ethernet Relay Kit.
I would like to have 2 questions cleared up before I buy the kit:
- in the datasheet I found an entry “10 Base-T port (10Mbps) compatible”
does that mean that it is ONLY 10 Base-T port compatible and NOT 100 Base-T port compatibe?
(will my 100 Mbps LAN speed be reduced to 10Mbps)? - Is the kit already assembled or have I to assemble it myself?
