VM186 Problem
I am having issues with this kit. I have connected the module to 12v LED SMDs, however it doesn’t react to the sound i make and the lights remain on constantly. Any ideas what the issue could be? I have tried it on a different set of SMD LED lights from another manufacturer and they work. But the spec on both LEDs are the same. So i’m not sure what the issue is? Any tips or help would be appreciated.
Is the blue led on the module reacting to sound?
Did you try with a different power supply?
If it is not working correctly, you should return the module for inspection/repair to your distributor.
