VM167 only 32 bit
and not on W7 64 bit? And in the future?
The VM167 is usable also in 64-bit environment (e.g. Windows 7 64-bit).
There you can develop software for it but you have to use solution platform x86.
[quote=“VEL255”]The VM167 is usable also in 64-bit environment (e.g. Windows 7 64-bit).
There you can develop software for it but you have to use solution platform x86.[/quote]
Thank you! In the folder it said 32 bit.
“You may write custom Windows* Applications in Microsoft
Visual Basic, Microsoft VC, Borland Delphi, Borland C++
Builder or most other 32-bit Windows application development
tool that supports calls to a DLL.”
You are right - there is not exactly said what is possible.
It is possible to compile 32-bit applications on 64-bit Windows too.
Also it is possible to run 32-bit applications on 64-bit Windows.
The VM167 DLL is 32-bit and it can be used in 32-bit applications only.
