Hello ,
i try to use the module on an Win10 based PC.
Where can i get signed drivers for Win10?
Hello ,
I’m sorry, currently there is no signed driver for the VM167 available.
To install the driver you have to disable the driver signature enforcement.
Here you’ll find the instructions how to disable driver signature enforcement in Windows 10:
howtogeek.com/167723/how-to- … d-drivers/
I prefer option 2.
Is it possibele to get the sourcecodes from the driver?
I’m sorry, the source code is not available.
We are developing an application that include the use of VM167,
I have a little problem with the driver in use with windows 8/10…
I found and try a procedure for deactivate the driver signature (and it works), but our customer can’t use this procedure for install the driver.
If i understand, the driver is made by Microchip, i absolutely need a driver that include the signature and work correctly with Window 8/10…
Can you help me?
Best regards
Hello
We’ll be looking to sign the driver with our own certificate, we’ll keep you posted.
Kind regards
Hello
We fixed this issue and created an installer which automatically installs the USB driver and SDK.
The installer can be found at https://www.velleman.eu/downloads/files/downloads/vm167_sdk_rev1818.exe
Please let us know if this resolved your issue.
Kind regards
